I have some trouble with units in the floormaster
all my drawings are in cm/mm (seeds, dgnlibs, ...)
today: if I open the floors from the floormaster: they appear in mm, (first floor : 2850)opening the grid manager is shown in cm
when creating the floors I was drawing in cm (first floor : 285)
If I generate a DV, the floor lines are showing something wrong:
here (from yesterday) the floor lines are drawn in mm, while they were saved as cm
the active depth in 3D is following cm from the floormaster
If I update the DV today , the floor lines are changing to normal height
what can be wrong
OBD 10.6.3.4
regards,
Rik
Hi Rik,
Can you please confirm whether the Design File Working Units set in the BB_FloorMaster.dgnlib , and the active file are the same or different?
RegardsSanchayan
sure, all my files dgn & dgnlib are cm/mm
when I opened the drawing today, the floormaster showed up in cm, a few minutes later, they are shown in mm ....
Is there a possibility to export a complete list of all dgnlib's loaded in a session, so I can examine one at another if all use the same units
I've installed the "configuration explorer" but I doesn't see something like a list of loaded dgnlib's
Is it possible that the BB_Floormaster.dgnlib was being modified for some reason? By default BB_FLOORMASTER_DGN points to that file under the workset's \standards\Dgnlib\ folder - is yours the same or similar?
