Problems with BB_modelseed.dgn for ArchDatasetUniclassGB
When using the BB_modelseed from ArchDatasetUniclassGB, the measurements, that appear when you select a coulmn or wall in plan wiev, appear in feets and inches, how do I change that to metric? The seed file works fine otherwise, everything else in metric.
This does not happen when I use an old seed file from V8 XM  spanish dataset, then it is in metric.
Then i cannot in V8i Architecture, select solids with the "choose by layer" option. I can choose primitives this way, but not building parts made by the wall or pillar function. Bug in V8i?
Whats the advantage of using the seed files from the new v8i datasets, over using old seed files?
Bentley Architecture V8i 08.11.05.46
ArchDatasetUniclassGB 08.11.05.54
