OBD Update 5 - Sub grids not showing in plan
OBD Update 5 - grids on drawing model are showing up, however cut displays both parts of the building grid
Building structure is skewed, there’s two orientations, lower grid is skewed and therefore slightly different, we select the lower level floor and make a cut, However, it displays both the upper structure grid and the substructure grid in the drawing model even if it’s set to only display the substructure as the active building in the saved view
We end up with both grids and not the substructure grid on its own
Cheers
Chris
