I am using OpenBuildings Designer CE update 5 (10.05.00.49), but I have also confirmed the below problem in the latest version.
When applying structural rules to plan views I always have Delta TOS set as one of the attributes all the applied rules.
I also ensure that when DTOS equals 0 that it is set to "Hide labels when delta = 0" in the view presentation options.
I am finding that this is not working as shown in the plan below:
It can be seen that there are a couple of variations in the DTOS display - one with brackets and one without.
I tried both options when setting up the rules but neither vanishes.
I should not see any form of DTOS where 0 appears.
Is this a bug?
Change coordinate readout to 6 decimal places. You'll find that the members are not all on the same RL and even a small difference gives the 0 RL. I've seen this in V8i as well. Only thing you can do is go through and make sure all members are on the same level. This has been put in an SR before.
FYI
I've been on this program since it first came out as Bentley Structural, so that was the first thing I checked.
I think this is a bug.
If you snap to the cut line from the DV, what RL does it give you though?
Everything is sitting at exactly EL4000, including both ends of the cut line.
I also have an override on the cut line as shown below.
Bummer, without seeing the file myself Bob, I'm only guessing from past experiences.
