AECOsim Building Designer SS6. Version - 08.11.09.866
Hi All,
What specific AECOsim Mechanical tool will I use to achieve the duct end cap detail highlighted in the image below?
Thank you
regards
Hi Henry,I would suggest you to try the "Place Rectangular Cap" Tool to get your desired end cap in this case. Please refer to the image below:Thanks & Regards!
Thanks Arghyakamal......I guessed so as well, but if you have a proper look at the image above you will realize the end tip is angled 45 degrees and not rectilinear. Which duct parameters will use to achieve this angled end?
The end caps available in AECOsim do not have options to provide angle. At the moment we only have rectilinear.Thanks & Regards!
I suppose you could also model a solid of the size and shape needed, then manually attach Cap DataGroup instance data to it if needed for reporting purposes.
