Cable Modelling
Hi All,
I intend to “convert a bunch of smart lines into conduits” with a dia of 68mm but unfortunately the largest diameter in the catalogue list is 30 x 30. How do I  get around this? More so, I realize the conduit is segmented which I really don’t want as the truth of the matter is that I am actually trying to model a “68mm dia cables” but “conduit” is the closest tool  within AECOsim I can use to achieve this or is there a way you can model “cables” within AECOsim
Thank you
