AECOsim Building Designer SS6. Version - 08.11.09.866
Hi All,
Please I just want to find out if it is actually possible to pint 3D pdf from AECOsim to a any render mode of your choice other than the default "Smooth".
Please note, I am aware you can change the render mode from the actual 3D PDF itself which is not my intention
thank you
Hi Henry,
Are you looking for something like this?
Answer Verified By: Steve Cocchi
Spot on Steve! Million Thanks
You're welcome! I'm glad that helped.
For reference, I found this wiki article that outlines the 3D plotting process so may also be helpful: https://communities.bentley.com/products/microstation/microstation_printing/w/wiki/9562/plotting-3d-models-faq
Thanks Steve.
