I've installed OBD locally and now want to point to a network location. I have modified _USTN_CONFIGURATION = R:Projects/ in ConfigurationSetup.cfg but every time I start ODB this variable is overwritten back to
Hi Simon,Please refer to Configuration Customization Guides and ProjectWise Custom Configuration wikis. Follow the steps mentioned here and let me know whether this helps.Thanks & Regards!
Hi
I have followed the Configuration Customization Guides CONNECT Edition - Custom Configuration - Part 1 : Initial Creation Steps though I already had OBD install on my laptop.
There must be a way to redirect to a network location after OBD is already installed?
Hi Simon,
This blog covers that: CONNECT Edition - Configuration Tips : Should I edit ConfigurationSetup.cfg?
Your existing ConfigurationSetup.cfg can be edited, but only in the [General] section.
An edited version of the file can be distributed to multiple machines using general Windows tools like batch files, etc
(I've added a link to this to the.... Part1 blog.)
Marc
