AECOsim Building Designer SS6. Version - 08.11.09.866
Hi All,
I have used the "Convert Lines to Raceway" tool to create a cable ladder run as shown In the image below, but I actually want it to run flat against the wall instead. I have tried implementing this using the "Front" view instead of "Plan" but still getting the same results.
Generally, how do you control the "rotation" or "orientation" of your raceway equipment at insertion.
Thank you
Kind Regards
Hi Steve,
Yes. with your recommended settings above, the raceway at insertion came vertical but not aligned to the wall as shown above until I also changed the "Angle (Horizontal)" value to 114° as I had to do some trigonometry calculations.
Is there a way to align raceway to an existing object in your model? Not everyone is good at mathematics you know
Hi Henry,
No unfortunately we don't have an "along element" option for placing Raceway. The best option I can think of is to measure the angle of the wall/element first, then use that value vs. manually calculating it.
