I have some dgn files with references who are saved with the relative path. A colleague have to use the files, but his PC uses other dive mapping.
Haw to set all references to "not saving relative path"
I've tried to change the checkbox and save the drawing, but always the save relative path is checked again after reopening the drawing.
Haw can I change this and haw to prevent the use of the "save relative path"
I've set the variables : MS_disallowFullPath=1 but no changes...
Regards Rik
Hi Rik,
When you set the Variable MS_DISALLOWFULLPATH = 1, you tell OpenBuildings not to save the full path. Please refer to the image below:
You can see more information in the Detailed Description section for this variable. You can try deleting that and then check.
Satadal
Hi Satadal,
the trouble is: the checkbox is checked,try to reattach the file,before opening the file in the "Reattach Reference" I uncheck the checkbox,open the fileconfirm (OK) the "attachment Prroperties"
If I now reopen the attachment properties, browse: the checkbox is checked again:so the changes are not saved
why?
