Hi
I have problem with loading and unloading my structural settings. I've tried to keyin:
tfsecmgr unload "P:\Proj19\19192 Mimer, Borlänge\3 Projektering\K\Support\Standards\Data\WorkSetShapes.xml"tfsecmgr unload P:\Proj19\19192 Mimer, Borlänge\3 Projektering\K\Support\Standards\Data\WorkSetShapes.xmltfsecmgr unload worksetshapes.xmltfsecmgr unload "worksetshapes.xml"
But none of them seems to help. That file read in from the configuration variable "section_shapes" and from this document, I've understood that "tfsecmgr reload" won't work in that case?
file:///C:/ProgramData/Bentley/Documentation/OpenBuildingsDesigner/10.6.0/en/htm/GUID-0DF82E88-58EC-5A77-5362-364A36CFBCE7.html?q=tfprefs.rsc
The keyin "tfsecmgr autoupgrade" seems to only reload one section-file, the svensk.xml. Guess it's the first alphabetically since dataset goes before organization?
Any ideas on how to update my sections without restarting the program?
Robert
Hi Robert,
You can try the Section Picker Dialogue (in CONNECT Edition, from Backstage Menu -> Settings -> Building -> Section Picker). You can try removing the sections from there and see if that helps.
Satadal
Thanks. But what I forgot to mention earlier is that I'm trying to build a VBA-tool to create new sections easily. Once it's created I would like to update the sections in my model so the user can use the new section right away. Therefore I need some kind of keyin to do this automatically.
