I am using version 5 10.06.03.04
I Went to model some pipework and the Victaulic catalog only option was only pressfit and st. gobain only has 50, 100 & 150 dia
how do I get the rest of the catalogs?
or is it the case, I need to use AECOsim?
on the project i am on people are talking of abandoning using the application software altogether and solid modelling everything
i have heard on of the larger consultants on HS2 is also going that way because the content isn't there
particually true of pipework and electrical raceways
On 18 Mar 2020, at 22:59, Steve Cocchi <bounce-F54ABBBE-F4D0-4BA1-889A-573A58D91E88@communities.bentley.com> wrote:
 <Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4TFHLUYVRQG4-jpg_2D00_70x70x2-jpg> Steve Cocchi David, Is this the same issue mentioned here? https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/139659/abd-ce---uk-or-gb-dataset If so it's probably best to continue here since it's not specifically related to the UK dataset; View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
David,
View online
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
Hi David,
So you are seeing the same list of Manufacturers in the drop-down list? If so, can you elaborate on exactly what is not working?
