Arial true type font display problem
Using Aecosim Building Designer CE update 4.
Labelling with Arial True Type font in Model design which looks good. When I reference in to Sheet design the font shows as outline only, no fill. Other notation with ATT font in Sheet design looks good.
So when I print the drawing the model text looks different to the sheet text.
I've trawled around but no obvious answer found. "Fill" is on in both View Attributes. Surely something really simple but . . . .
