Hi
I'm setting up architectural annotations for slabs. I've noticed that I need some kind of edge of the slab visible in my callout for the annotation to show. That's not a very good solution. The cut walls and the edge of the slab are more or less always in the same line. So to show the annotation I need to create an opening or something, to have an edge of the slab visible. Or am I missing something here?
Another problem I have with showing annotations is for columns. When I create a plan-callout and don't have the exact same section for columns on two floors both columns will show in my drawing. And since both columns show (we always use show hidden edges), one as cut, and one as hidden edges, both columns will have their annotations displayed aswell. There should be a way to only include the cut columns annotations.
Both the cut (white) steel column and the hidden edge timber (red) column have their annotations displayed. This means I have to hide half of the annotations (around 50) manually.
Robert
Hi Robert, for the Slab Annotation you can switch of the Wall Levels.
For the Column Annotation I would suggest using a Criteria Set for teh Drawing Rule
I've been trying to solve the column problem, but I don't really get your idea? What criteria would fix this?
