Hi
I want a box around my text in the annotation cells. But I want the box to adjust after the length of the text. Is this possible?
Robert
Hi Robert,This needs deeper investigation, you may probably file an SR on this. In the mean time if I get something, will get back to you.Thanks & Regards!
Hi Robert,
You can try and use a Text style with a Background assigned. The Border adjust to the Text length.Please let us know whether this helps.Thanks & Regards!
Hi, thanks. Not quite. I display two properties, so it looks like this for me with your solution:
Guess it's because I can't find a way to include both properties in the same text element.
I would like one border to include both properties.
Hi Robert,Thanks for the update, will have to look into this.Regards,
Is it possible to place multiple properties in the same textelement? Cause that would solve it.
