I'am looking for an off-line updater/installer?
or someone who can explain this errors:
Failed to acquire payload: PowerProductPackage to working path: C:\Users\rbe\AppData\Local\Temp\{E3E9AED6-E6FA-4D72-B7CD-E814036963DF}\PowerProductPackage, error: 0x80072efd.[4414:0054][2020-03-26T11:31:43]e000: Cannot download package PowerProductPackageApplication requested retry of package: 0x80072efd, encountered error: 0x13e8f98. Retrying...
Error 0x80072efd: Failed to send request to URL: cdnllnw.bentley.com/.../openbuildingsdesignerx64.msi, trying to process HTTP status code anyway.[4414:0054][2020-03-26T11:32:37]e000: Error 0x80072efd: Unknown HTTP status code 0, returned from URL: cdnllnw.bentley.com/.../openbuildingsdesignerx64.msi
Hi Rik,
Which version are you trying to install?
Marc
latest: OBD 10.06.03.04 through the connection center updater, installed is AECOsim 10.03.00.04,
but there are company license problems: we are merging 2 tenants to 1 (total 14 OBD licenses) , Bentley has extended the existing licenses, the new merged tenant doesn't exist yet (after more then a year) now it looks the OBD lic is included, the AECOsim not (?) - but can this hold the update from downloading?
Licensing does not limit what you can download. AECOSIM and OBD operate on the same licence.
We have recommendations for upgrading from AECOsim CONNECT to OBD.
I suggest creating a deployment image for OBD 10.06.03.04, that way (assuming it is sucessful) you know that the download aspect is not the problem.
Marc, about the licenses:
sure our licenses are bought in1989, no problem the consecutive product names have no problems upgrading the product. but now, the new tenant was not yet created, the old licenses were expired, Bentley reactivated the old licenses, and now all my old installations can't sign in, the new OBD versions are signed in, after the license wizard: but AECOsim stops working after 15 min. OBD not.
I believe Update 3 used SELECTserver licensing while Update 6 (actually since Update 4) uses Subscription Entitlement Service (SES) licensing: https://communities.bentley.com/products/licensing/w/licensing__wiki/37813/subscription-entitlement-service Also, SELECTserver licensing does expire in January of 2021: https://www.bentley.com/en/license-administration-services
All that said, as Mark mentioned the licensing mechanism should not affect the ability to outright install a product. The "payload" errors in the OP indicate problems downloading prerequisites/sub-installers while running the OBD installer, but it's unclear if or how that connects to changes in licensing.
