Personally, I'd like to see this under modify, or better still, Common Tools. One less location to worry about as Data\Reporting is hardly used.
Woops, found under Common Tools, but Modify would be a good addition.
Hi Bear,
You can add/modify buttons as per your requirements.
Warm Regards,
Subhamoy Kundu
I'm fully aware of that, but why have it somewhere not well used in the first place. Modify just seems like a more sensible location.
SR7001049276 raised.
The Common tools group is included in most tabs, including Modify, so technically it is available there.
I know it's included in the Data/Reporting tab in a second location, but that tool group (E) is meant for attaching Building data to existing elements (DataGroup and Family/Parts). The tools in the Modify tab, on the other hand, are more for modifying element geometry vs. non-graphic data.
