Hi
I have some problems with callouts. In the image below you can see how the model looks in 3D. The walls align with the foundation and the ground beam.
The beams are connected with the connect walls (connect forms as L (bisection)). This is how it looks in wireframe: (marked corner is the one in the image above)
But the callout makes i look like this: (It goes for both the saved view in the design file where I create callouts, and in the drawing file.)
Totally messed up. What could be the reason for this?
Robert
Can you attach the file Robert
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Yes, here it comes. And strangely. I created a callout "struct - plan" and one "struct - grundplan" (foundation plan). The foundation plan is the one I used before and gets messed up. The regular plan works just fine. I've attached the drawingseed as well, we've made some changes to it from the dataset_SE one.
DrawingSeed_Structural.dgnlib
K-15-V-091 - kopia.dgn
Hard to say why, since struct-grundplan was cached. Once switched to dynamic mode the results were correct, as they were when re-caching it.
Hmm. It seems to work for me too right now. Not sure if I've done something that should affect it. But ok. I'll get back here if it happens again!
Answer Verified By: Steve Cocchi
Sounds good.
Always glad to help with a magic fix on occasion.
