Hellos,
Is there a quick way to jump to the folder containing the Cell that the Modify/Place object tool is looking at?
This would really be helpful. Edit Catalog Item opens up the DGS Catalog Item xml but there doesn't seem to be a path to where the Cell is stored.
The old right-click Building Element Information did provide an Edit button but only for PAZ Cells. It also automatically loaded PCS.
Having to go to the Backstage and rummage through the Config settings to find the path(s) is a bit of a pain.
Hi Dominic,For PAZ you can still edit from Building Information Tool but not for .cel or bxc as user has to find the path but its always in cell folder of dataset and workset.Would you like me to file an enhancement for this?Thanks & Regards!
Yes, please...
