Probably another common question but I have set up my AECOSim interfaces over the years to perfection in terms of everything just where I like it! I realise that the OBD interface is different to the interface I am used to, I still use the older V8i Select Series 6 style legacy interface.
However can I at least import my right click menu set up, function keys, fonts and button assignments etc?
Many thanks
Keith Cameron
Hi Keith,With respect to your query on interface migration the last paragraph of OBD U6 Release Update has all the information.However for Dataset Migration, File Migration, Project Migration you may click on the links and follow them.Let us know whether this has been of help.Thanks & Regards!
I wil have a look thanks.
