Hi All
Within a call-out structural columns show just as centre lines, if the view is demoted the columns display correctly, however any hatching will disappear
Promoted View
Demoted View
Using OBD 5
Any suggestions
Cheers
Chris
Hi Chris,Can you please check if any Structural rules are applied in the Structural tab? If yes, please check the result after unchecking the required rule.
Hi Anik,
Currently no rules are set in any of the discipline tabs
Chrsi
Hi Anik
Drawing seed files, we have used initally a default structural section seed, I have tested using a Arch seed that comes with the applicationDataset is based on the out of the box UK dataset
I seem to be struggling to upload a sample files which is 30Mb - tried twice each time it errors out and nothing is posted (the file says it has uploaded)CheersChris
Hi Chris,You can try uploading the file here.
Thanks I uploaded the file
Did you receive the file I posted?
Hi Chris,
I had a look with your file. I did not see any existing sections or drawing views. However, I tested by taking new sections. It is working as expected. I would request you to file a service request through which we can have a more detailed discussions about this.
