Hi all, I'm facing a big problem. Let me explain :
My suppliers delivers cad files from all the format possible ... 3D step, DWG, etc ...Those models are huge and does not fit in my workflow. I wanna simplify the received models.
Is there a way to keep only the visible solids like hln does for the 2D part ?
Hi Julien, I would like to suggest you to make an IFC file of that model and import that in your workflow. Although STEP(.stp) files, DWG files are also can be smoothly import into our application. However in this case you can go with the IFC tool.HTHRegards, Arindam
