AECOsim Building Designer SS6. Version - 08.11.09.829
Hi All,
The areas highlighted in the image below are black objects and texts printing (using AECOsim directory pdf.cfg) in grey color and i really cannot explain why?
Before you make any suggestions, i would like to make you aware of the following:
- This abnormalities is only experience in two only 2 of my AECOsim files. The rest files print okay so i assume its a file specific problem.
- but whenever i open these 2 files in Microstataion SS3 (08.11.09.578) and make a print (using Microstation directory pdf.cfg) , everything comes out well as expected.
- Since they print well in Microstation, each time i am attempting to print them in AECOsim, i borrow the pdf.cfg in Microstation directory instead and still no joy
- i don't use overrides
So guys, i am just a bit confused on how to troubleshoot this
I welcome all you suggestions
Thank you
H
Are the views in the two files in question drawing models? If so, in the other files that do plot as expected are those drawings as well? Just looking for something in common (or not) between the two sets of files.
Hi Steve,
Yes. they are all drawing models referenced into the sheet. Meanwhile, i have just come to realize that only all objects with these funny grey display are all live in their sheet models. The drawing model saved views are perfect.
So... the elements displayed as grey were placed directly in the Sheet model, with the remainder as reference attachments?
Yes. you are absolutely correct about that.
Why do you ask?
Henry,
It is possible that the reference attachments containing the grey elements have a colour adjustment applied?
Marc
