Hi
I've followed the steps from this link to create a parametric cell with an attached part. https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/40981/how-to-create-parametric-objects-using-cel-parametric
On placement it honers the level color, but if I change one of the parameters for the cell, the color changes to white (see video).
Why is this? Can I do something about it?
Robert
Hi Robert,Please send us this parametric cell and its corresponding xml to investigate at our end. You may also raise a SR.Thanks & Regards!
Hi Robert,
Have you got any solution for the issue?
because I too experienced the same and needed any solution for this same issue.
How to display assigned "color" or "Render Material" of the user defined parametric cell in model?
