I have published a i.dgn for review in Navigator.
The document I published as a i.dgn has several references attached in it... References getting published successfully... and I can see all references in Project Explorer in Navigator...
However issue is '+" sign is appearing in front of all references, after clicking on it supposed to show the all Layers/Levels in the references... which isn't happening for all the references except the one I marked in red (splease see below screenshot). It shows all layers/levels which are in the file (please see screenshot). Same is not working with other references, when clicked on "+" to collapse it does not show levels but collapse option also vanishes (Screen shot is below) ... (I created a single package using publish dgn dialog, Setting screen shot is also attached).... any solution on this one...
Balkrishna
Hello Balkrishna,Going by your description I believe you are facing the issue with Bentley Navigator. You can post questions related to Bentley Navigator here.Kindly mention the version of the product while posting your query.RegardsAditya
