Hi All,
I'm new to using AECOSIM/OpenPlant. Can you help me what is the batch process script that I need to write in my command file if I need to create i.dgn file format only, for my dgn files without publishing .imodel file. I don't mind if it publishes dgn.i.dgn too. I just need FILENAME.i.dgn file and not FILENAME.imodel.
Any help would be much appreciated.
Thank you all,
John
Hi John,I would recommend you to kindly have a look at these wikis Batch Process Series Part 1 & Part 2 and let us know whether this has been of help.Thanks & Regards!
