in the DV are walls patterned, all single pattern tiles are snappable,
this is not workable to place dimensions - patterning should be by default "NOT snapable "
Is there a way to make the walls snappable and disable the snap to the pattern
Regards Rik
Hello Rik,This is an known issue.Please file a service request, we'll attach the defect to it.Thanks,Sayanti
