i need to import mechanical files from AECOsim SS6 to OBD connect Update 6
when i have tried copying the elements into the ODB file i get this message
does this mean that pipework or ductwork modelled using the aecosim applications are not compatible and need to be re-modelled from scratch?
is there a patch or work-around?
Hi David,As you have copied elements from AECOsim SS6 to OBD CE U6, please try and run a DG upgrade now. Let us know whether this has been of help.Thanks & Regards!
Answer Verified By: Steve Cocchi
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
