When I try to create a Steel Column Schedule in OpenBuildings Designer v 10.12.0.41 I receive the error message stating (Column Schedules: Failed to locate drawing seed "Steel Column Schedule"). In the Graphical Column Schedule Settings dialog box it seems to be reading the drawing seeds in the DrawingSeed_GraphicalSchedules.dgnlib. Am I missing a configuration variable? or is this a bug in CONNECT Edition?
I have a same situation, Did you sort this out? Can you share your solution if sort out?
The solution that worked for me is in the above thread. I ended up leaving the name of the original dgnlib the same and changing the variable to look for it in the workset.
