When i hold the cursor over a marker or a callout, the mini toolbar appears far away. And it vanishes before i can reach it...
The only way i can get it working is to anticipate and be very fast...
How can i solve this ?
Chris
Hi Christophe,You can delete your preferences folder corresponding to this location - C:\Users\User.Name\AppData\Local\Bentley\OpenBuildingsDesigner\10.0.0\prefs in your machine and a new one will be created the next time you open a file and all tool boxes should be reset back to their default settings.Please let us know whether this has been of help.Thanks & Regards!
Answer Verified By: chris Cher
Thank you.
I worked, the mini toolbar is back at the correct position.
regards,
