Is there a way to have for example a DataGroup Item 'Brick wall' which gives me the option to chose a width when placing, that shows the ones that are 9cm dfferent then those that are 14cm in my 3D model.
I can only think about making a second part, but that would also create the need to make 2 DataGroup Items, to be able to link them both to a different part. Which seems a bit overkill just to have this visual difference in my 3D presentation?
Any ideas?
Thanks, that seems to work :-)
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
