is there an existing catalog definition (or how to define) for active attributes (level, color, class, ... ) to attach to catalog items where active attributes can be set for placing walls / slabs / .... I want to preset some of the attributes
I want to make sure a wall is placed in primary class, an opening(element) in construction class
Regards RikOBD 10.6.3.4
Hi Rikr,
These can be added using the DataGroup Definition Editor, please take a look at the help topic "DataGroup Definition Editor dialog" for initial guidance. When creating a new definition file you can choose to locate it in your active project.You may also have a look in this video https://www.youtube.com/watch?v=EImxjw6uros
Thanks & Regards!
Hi
I know how to use datagroup defintions, the question is: is there an existing system definition to attach, or, if not how to define attributes like element class in a new datagroup definition
regards Rik
HI RikR,
The datagroup systems is limited to the meta data you what to track and record for reporting purposes. The family and part system takes care of the element attributes, however even this does not extend into Element Class. As far as I am aware all walls does and slabs etc will be primary class.
Can you give some use cases of how you create openings and why you need them to be Construction class. How do you want opening elements to behave once they are a construction class?
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
the active class is used when placing elements, also for walls, objects ....
but there is not a "change element class" for datagroup elements (the "change element" tool does NOT affect datagroup elements.so if the active class is set to construction, the wall is placed in constructionnow I want to reset it to primary classit would be nice to have this setting in the datagroup definition so when placing datagroup elements the class is set to the desired class
maybe an extra setting for the "apply part" tool?
