parametric solids to SKP -> wrong scale
I have a model with normal solids and parametric solids.
When i export to SKP (sketchup), normal solids have the good size but parametric solids are way too big.
1cm -> 2,54m   wich seems to indicate a wrong unit management (i am working in meters / millimeters).
Converting parametric solids to normal solids correct the problem (but is not a solution).
The problem occurs only with Openbuilding U6. The same file opened with Connect U13 exports correctly.
regards,
chris
