OBD - Multiple installs (versions)
I need to install several versions of OBD.  Each one is for a specific project.  As you are aware if I install OBD 3 and then 4 or 5 or 6 etc, it will override the previous version.
How can I have multiple versions installed so I can interact with the various projects.?
Ian
