In SS I did use the Project Explorer, but in Connect (U6) I don't see it, is it removed?
Also, in the dgnlib-folder in my Dataset I have a file LinkSetSeed.dgnlib, from what I find about it is that it's support of the Project Explorer. So do you still need it?
Hi Stefan,I guess your answer is in this blog, please find time to go through this.Thanks & Regards!
Hi Stefan,This feature is still present & has been enhanced in CONNECT, you can find Explorer by typing in the search bar in the ribbon also, please refer to the image below.
Thanks & Regards!
Answer Verified By: StefanC
Thanks, I was always looking for "Project Explorer", but seems to be just "Explorer" now.
That blog seems to mention the LinkSetSeed briefly, but I managed to find the correct settings with that one.
Windows 10 pro
OpenBuildings Designer Connect Edition Update 8 -version 10.08.00.44
