AECOsim Building Designer SS6. Version - 08.11.09.829
Hi All,
can someone please briefly explain to me how the THICKNESS and HEIGHT in the dataset explorer settings highlited in the image below affect the display of parts. I have checked the help but could not find anything concrete.
Thank you
H
When you use the 'Apply Part' tool, you got some options to check/unckeck, the last ones are 'Apply Default Height' and 'Apply Default Thickness'. That's where it is used.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
Answer Verified By: Henry Eduvie
Hi Henry,
These were used by the quantification tools that preceded the DataGroup Catalog, so have limited functionality these days. The dimensional properties and values in the DataGroup should be used.
Marc
Oh I see. Well understood ...Thank guys
Hi Guys,
could you please help with this particular urgent topic i have just posted. I have been battling to resolve this for the past 6 hours.
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/197484/missing-level-and-object-in-dynamic-view-drawing
