Hi All
I womder when bentley is going to fix the quantification tool.
It used to work fine
now I receive an error that the file is missing.
Any Help please.
Than you
Hi James,Can you please elaborate on this issue regarding the version of the application, your workflow and a corresponding error image/ screen grab, you may also provide us any enhancement/defect that has earlier been raised to trace it.Looking forward to hear from you.
Thanks & Regards!
As Orgho wrote, there simply isn't enough information to make an informed reply.
However, if you're referring to the old Quantify tool (vs. Schedules) you could be seeing something like this:
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/38848/tfdir_5f00_setting-points-to-an-invalid-path
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/38010/aecosim-opens-with-xml-and-or-settings-error-message-boxes
