Place By Flood Slab Placement
AECOsim Building Designer SS6. Version - 08.11.09.829
Hi All,
Can someone please demonstrate to me how i can convert the hatched region illustrated in the image below into a slab (1300mm Thickness) particularly using the "place by flood" option.
I have used the "create region" tool to define my region but whenever i try to flood the newly created region, it doesn't recognize it.
Meanwhile, I welcome any other suggestions for  achieving this slab form as long as it can be listed in the dataset explorer for scheduling/reporting
Thank you
H
  • Hi Henry,
    I've added video for your reference , let me know if you are looking for the same.
    HTH,
    Rg,
    Sandeep
    Answer Verified By: Marc Thomas
  • Hi Sandeep,
    Million thanks for the video and i really appreciate your help on this. Meanwhile i have a quick question for you, i realize you patterned the area before creating the region, is this step compulsory as i do not do this before creating the region? Also, my master units is in METERS while my sub units in millimetres, is my solid working area settings below appropriate? if not can you screen shot an ideal settings?
  • Hi Henry, no patterning is not required at all, I was just trying few things which also got recorded :). BTW SWA related query is responded by Marc in another post.
    Rg,
    Sandeep
