Hi there, my view attributes don't appear correctly. Now I can't use it anymore. How do I repair this? Please help, regards kind Marc
Hello Marc,
Can you elaborate the problem in detail? Also, mention the version number of OBD?
Swati Nagre
Hello Swati, I just did a repair installation but it doen't work. I am using OBD version 10.00.18.25. Kind regards, Marc
Hi Swati, herewith I send you a better screenshot of the view attributes menu. I don't know how to get it normal and can't use the view attributes at the moment. kind regards, Marc Op 25-5-2020 om 06:31 schreef Swati Nagre: Update from Bentley Communities Swati Nagre Hello Marc, Can you elaborate the problem in detail? Also, mention the version number of OBD? View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse. --
View online
Hi Marc,
Can you re-check the build number? I don't recall 10.00.18.25.
That aside, you could try renaming your preferences to see if that helps: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior
Answer Verified By: Steve Cocchi
Hi Steve,
I am using update 6, and indeed I solved it by deleting the 'prefs file'.
thanks and kind regards. Marc
Update from Bentley Communities [AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.] RE: view attributes doesn't work correctly Steve Cocchi Hi Marc, Can you re-check the build number? I don't recall 10.00.18.25. That aside, you could try renaming your preferences to see if that helps: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/23227/regenerating-preference-files-to-help-resolve-random-odd-behavior Did this answer your question? Verify it as the answer or Reject it as the answer View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
Glad to hear it, Marc!
