Hi all,
I'm new to this software hence the probably simple question I'm about to ask. I have the Open Buildings Designer CONNECT Edition and can't seem to locate the very useful looking task bar seen on the left-hand side of all the youtube videos and tutorials explaining how to use the software. Can someone please tell me where I can find this as it is driving me crazy. I have to stop the video I'm viewing to look for whatever tool they're talking about as they can access quickly on the toolbar I'm referring to. All help is much appreciated and thanks in advance.
Cheers,
Jack.
Hi Jack,Can you please let us know the version of OpenBuildings Designer you are currently using? You can find the version following this wiki. Also share with us a screen grab of the task bar you are searching for. Looking forward to assist you further.Thanks & Regards!
I'm using Version 10.0.18362 Build 18362
Hi Jack,
Please go to File>Help>About OpenBuildings Designer in CONNECT and paste the version here.Thanks & Regards!
Hi Jack, where did you find that number?
You should see a dialog like this:
Marc
