Is there any way to disable "Create Sheet model" by default ?
regards,
Chris
Hello Chris,
Thank you for raising the query. I would like to inform you that this a default option within application. You can change this settings through the drawing seed definition. While creating a new drawing seed, you can change this option by modifying seed definition. After working on that seed file, you will not get this "Create sheet model" option. You can go through this link for a learning session-https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=113058&mcId=103196 Please let me know whether it helps.
HTHThanks & Regards,Arindam Roy
