Hi Guy,
What is way to show and edit the level ( Top level of Footing and Bottom level of footing) when modeling it? same question for column, beam, etc
Hello Nguyen, Thank you for posting your query. I would like to inform you that you can showcase the assigned level from Level Display which is under Common Tools. You can also create/edit new Levels from Level Manager. The Level Display and Level Manager both are under Levels tools.
HTH.
Thanks and Regards, Arindam Roy
Hello Arindam,
I think Level Manager using for turn on or tunr off object. I want to show more information in Properties dialog box of object such as top level and bottom level or more to inqurie the Object and modify the properties of them?
Can you take a short video
Hello Nguyen, I would like to request you to please file a SR regarding this query. Our support team will entertain this issue and if require will have a live meeting too. HTHThanks and regards,Arindam Roy.
