Hello community,
Why when I'm using the OpenBuildings Software when I try to modify solids I always get the below response? I thought this software was supposed to make my life easier, not make me want to cry ha.
The Feature: "Difference #39" cannot be created with current settings and geometry.
Can someone please help me. What settings and geometry do I have to use / change to be able to use these features?
Much appreciated in advance.
Cheers, Jack.
Hi Jack,
This post is moved to English queue.
Warm Regards,
Subhamoy Kundu
As Jan outlined above, there is not nearly enough detail to provide a viable answer. The type of solid, the feature you're attempting to add, and its orientation in relation to that solid all contribute to the end result. Or lack thereof in this case. Screen captures and/or an example DGN file are needed.
