I want to add some project- datagroup itemsI can create the items, they show up in the catalog editor, (here VCA_GC01)
i can safe
but I do NOT see the items for placingafter reload the application:the types catalog is still there, but seems to be empty: (no items any more)trying to add again the items says the items are still there .... ?
when I make the same on organization level I see the new items
What am I missing to add the items for placement (configvar to add the project items to the toolsettings?)
I stay in the same project
OBD 10.6.03.04
Regards Rik
Hi Rik,
I'm sure you "Validate" catalog editor after creating item at Project / Workset level. Did you see any error[s] there?
Aniruddh
I tried the same steps you mentioned and also create catalog on workset level , see image below
The only thing is I faced refresh issue, so when I restart the session everything works fine. Can you please try the same ?
Rg,
Sandeep
now for some reason it works, what I've done: I don't know;
but:
now I have Project Related items:every thing works fine...
until I use the selector: if I select (architectural)items are filtered, but the Project related items are not shown anymore:
I've added object dicipline - but no result
is something else missing to show up by the filter?
Did you add your new items to a filter?
Marc
Answer Verified By: RikR
Thanks Marc, I don't know about this setting to "Modify Catalog Filters"
