I have an IFC file with a IFC Site surface (shown below in BimVision)
When i reference (or import) the IFC in OB U6, i have only the boundary, not the terrain mesh.
is it a bug or a (sad) limitation ?
regards,
Chris
Hello Chris,
Thanks for posting the question.
Would it be possible for you to share sample IFC file?
Aniruddh
Hi Chris,
IFC Site [Mesh ] can be seen when referenced , Please see image below.
Can you please check if you have all used levels ON from reference ?.
If you still not see it, kindly post IFC file.
Rg,
Sandeep
I added function IfcSite_getElement2x3 for the fixing of this defect, but users/customers need to modify transform file of ifc ECSchemas\Ifc\IFC2x3\IFC2x3.transform.xml to open this file.
<ClassMapItem internal="IfcSite" external="IfcSite" elementMethod="IfcSite_getElement2x" active="true" />
to
<ClassMapItem internal="IfcSite" external="IfcSite" elementMethod="IfcSite_getElement2x3" active="true" />
Answer Verified By: chris Cher
Works perfectly. Thanks for this.
I suppose this should be added to the next update.
The changeset has already added to the build. In order not to conflict with other elements used IfcSite_getElement2x, we temporarily change the xml file to import this element.
