I have a model with all my columns for all 7 floors. Most have splices and change sizes as they go up.
When I run Graphical Schedule for Steel. it creates "Steel Column Schedule Report". but not all the steel columns show up?
I get about half the columns...the other half, only the column splices show up.
I also don't get any offset dimensions for columns that don't start or stop at the floor grid levels.
All columns are "Main Column" instances and all are Part "Steel::Columns"
All columns are Code "cisc" & Type "I Shapes"
I found by deleting and regenerating the "Steel Column Schedule Report", I get inconsistent results. I don't always get column labels to show up either.
Any ideas as to why this is happening?
Hi Gary,
To start, which version are you currently running?
Hi Steve,
I'm running OBD Update 6.
Gary
Gary Manuel
OBD 2023
Windows 10 Pro
OK, thanks. At least we can remove earlier versions and/or issues from the equation.
Do you get any errors when creating the column schedule? If you've created them before, is this the first case where it's not working correctly and/or resulting in these specific symptoms? The inconsistent results part is the first thing I'm looking at, thinking that perhaps the missing columns are related.
