Hi
We have an issue which is irksome to say the least.
We installed ABD with the GB data set, which is supposedly the one to use.
Opening on the desk top all is good.
But if we create or open a file on PW, then access the data set lib, it shows as US_dataset.
The PW database belongs to the client, we have passport access.
I am looking for a reason this is happening so I can pass onto the client, as they claim its not their configuration issue.
Colin,
we need more information to help you.
is there a projectwise managed workspace in place?
what version of the application is the managed workspace for?
are you opening a file from projectwise by either "double-clicking" or "right-click menu and open" or are you launching the application first, then opening the file?
what version is the PW server
what version of the pw client is installed
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
1. MANAGED PROJECTWORK SPACE IN PLACE BY CLIENT
2. SE5 AND SE6 ABD
3. LAUNCH PW, THEN RIGHT CLICK/OPEN
4. NOT KNOWN
5.08.11.11.590
oh and PW server i beleive is hosted by bentley... company Flo (UK)
also its not only myself that has this issue.
Other user keeps getting crashes when choosing view attributes in a 3D file
All the issues I am sure are to do with PW credentials assigned to our log-ins..
But I have to convince the client that this is the case.
Hi Colin,
Could you clarify what you mean by SE5 and SE6? I'm assuming you're referring to V8i SELECTseries 5 and 6, but even if so, each should have its own workspace + dataset.
