One of the other reasons I migrated over to OBD from my Select Series 6 is that I was having recurring issues with the pop up context menu. Basically it can go blank at any time and I have to exit the application. It is now happeneing with OBD. Running a twin screen system but not two application windows. You can see the tall blank menu in the screenshot below.
Anyone have the same issue and a resolution?
Hello Keith,
Can you please elaborate about what context menu you are trying to refer? Is it the property dialog?
Regards, Alifur
It is the right click context menu which brings up tools. It greys out and nothing will reactivate it apart from an application restart.
Hello keith,
Please close all the OBD sessions and then can you please go to this location (C:\Users\(User_name)\AppData\Local\Bentley\OpenBuildingsDesigner) and rename the prefs folder. After that, open a new OBD and then try to check whether this issue still persist or not.
OK, what do I rename the folder to? Will keep an eye on it once I've done that. It happens at random times.
You can rename it to anything you like. It is just to keep you previous settings of OBD.
