I am having trouble exporting a COBie spreadsheet from AECOsim V8i Select Series 6. Elements and their information are exported normally under the "Type" tab but the "Component" tab is always empty! Any ideas?
Hello Yehia,
Can you please share some screengrabs so that we can better understand what is the issue that you are facing?
Regards,Alifur
The component tab is empty. The type tab has the information exported normally.
Hi Yehia,
Component tab will show components if those are associated with spaces. Can you please check once if you have spaces defined for the rooms ?
Rg,
Sandeep
Answer Verified By: Yehia Elsayed
Hi Sandeep,
Can you walk me through the process of how to assign spaces to MEP components?
Thank you.
