Hi Everyone
i am in need of modeling a Precast I Beam Girder in Aecosim So i am here to ask Geniuos to help produce a cell which can be modified. as per length.
kindly see attach sketch. the beam starts with skech 1 from support and say like after 2 meters its transition to sketch 2.
thanks regards for your time.
Hi Muhammad,I would suggest you to have a look at the following blogs, to give you an idea on how to create parametric sections:
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/creating-a-parametric-steel-section
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/creating-a-parametric-steel-section-1639437554
Since you are mentioning AECOsim, you might want to have a look at the Communities related to Building and AECOsim:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum#pifragment-25858=1
As a last note:
you have started this discussion in the MicroStation [Archived] MicroStation V8 2004 Edition DWG Forum , since this forum is specific to V8 2004. please place next questions/remarks you may have in the active MicroStation forum:https://communities.bentley.com/products/microstation/f/microstation-forum#pifragment-25830=1
I hope this is of help.
Henk
Thanks sir for sharing info. i posted there
